Need help with cluster swap
I'm trying to do the cluster swap. I have the idiot light version with the shift indicator on the fuel gauge. I am trying to remove the whole cluster but I can't because the little cable that connects to the shift indicator is not long enough. How do I disconnect it?
I think you need to remove the clear plastic lens to get to it to disconnect it. Then once its disconnected you can pull the cluster far enough out to get to the speedo cable in connectors. Be careful tho, the speedo cable clip brakes easy if you pull it to far.
