pilotblake Posted April 21, 2009 Posted April 21, 2009 Before anyone says search..I did, but what are the weak points of the 86 MJ for some reason I remember the engine compartment being smaller or something like that, is there anything else. All I know about the jeep at this point is that it is it runs its a 4x4 and a manual transmission.
JeepcoMJ Posted April 21, 2009 Posted April 21, 2009 Before anyone says search..I did, but what are the weak points of the 86 MJ for some reason I remember the engine compartment being smaller or something like that, is there anything else. All I know about the jeep at this point is that it is it runs its a 4x4 and a manual transmission. that's a little too vague. it has the same weak points as any other comanche, except that it could have a 2.8 liter gmc v6. that engine is worthless and you CANNOT make it worthwhile. no matter what you do, it's junk. if it's a 4 cylinder don't worry about it. and the engine bay being smaller is a much-disagreed-upon myth. some have that issue, some don't. no guarantees. if it happens to be smaller, it would only be by maybe a couple inches around the right hand side of the transmission hump on the bottom of the firewall. if you want to do a 4.0 swap on one, you need a new hood, new radiator supports (this includes the steel behind the headlight buckets), and a new front crossmember- all from a 4.0 liter.
rickmodelt Posted April 21, 2009 Posted April 21, 2009 just swaped 94 4.0 with aw4 trans Into my erly 86 mj only diferance in firewall I see is were the 86 dos`nt have the dimple for the floor shift cable.I Used the colume shift.I had to change core suport and hood . Also wireing harnes`s engine,and dash.Was easy but time consuming.
