dakal Posted May 28, 2009 Author Share Posted May 28, 2009 got my sound and vibration damper. this is getting ready to apply it. Image Not Found this is first coat. Image Not Found i will apply one more coat today, then tomorrow apply more of a sound coat. different stuff. it was their recommendation. need to go on a job, so won't be able to work on it for a while. :yes: i finally found the leak on the drivers side. i was looking up at the firewall when i noticed sunlight where there shouldn't be. it was coming from the top of the hood release cable as it goes through the firewall. you can't see it otherwise. so don't go by what you can or cannot see. just coat everything that goes through the firewall. it was just a pinhole. :thumbsup: Link to comment Share on other sites More sharing options...
dakal Posted May 29, 2009 Author Share Posted May 29, 2009 third and last coat Image Not Found i have some left but it dries fast. the sides will get done. replacing the doors someday. off to work Link to comment Share on other sites More sharing options...
dakal Posted August 5, 2009 Author Share Posted August 5, 2009 started again with the wiring. drilled holes in the dash to fit the gauge holder. finally Image Not Found before gauges Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted August 5, 2009 Share Posted August 5, 2009 looks good :thumbsup: Link to comment Share on other sites More sharing options...
dakal Posted August 5, 2009 Author Share Posted August 5, 2009 thanks Link to comment Share on other sites More sharing options...
maddzz1 Posted August 5, 2009 Share Posted August 5, 2009 great job, can't wait to see the finished product. Link to comment Share on other sites More sharing options...
dakal Posted August 5, 2009 Author Share Posted August 5, 2009 with gauges installed Image Not Found will wire them up. can't find the connectors though. will look again, then look for new ones :ack: old age, can't remember the gauge for the open hole. when i do remember it, then can't find it. so for the time being, o.h. Link to comment Share on other sites More sharing options...
Automan2164 Posted August 5, 2009 Share Posted August 5, 2009 old age, can't remember the gauge for the open hole. when i do remember it, then can't find it. so for the time being, o.h. According to this: Image Not Found Youre missing the EGT. Glad to help ya out of old age. :thumbsup: Rob L. Link to comment Share on other sites More sharing options...
dakal Posted August 6, 2009 Author Share Posted August 6, 2009 thanks, but i can't find one :dunno: Link to comment Share on other sites More sharing options...
dakal Posted August 7, 2009 Author Share Posted August 7, 2009 most of wiring done Image Not Found need to buy sensor for speedo to finish that. now i move back to mj for finish up work if anybody can help me find the egt it would be appreciated also, i have a separate grounding block for my grounds. i bought it from wire works. Link to comment Share on other sites More sharing options...
dunl Posted August 8, 2009 Share Posted August 8, 2009 got my sound and vibration damper. this is getting ready to apply it. What exactly is that product? Link to comment Share on other sites More sharing options...
dakal Posted August 8, 2009 Author Share Posted August 8, 2009 it is called: spectrum 1 gal size damplifier pro 1 gal size i buy it a second skin audio on the net Link to comment Share on other sites More sharing options...
dakal Posted October 29, 2009 Author Share Posted October 29, 2009 finally got back to doing the mj. assembled the dash. i think the best pic will be with it not installed. sooo Image Not Found Link to comment Share on other sites More sharing options...
