mjeff87 Posted April 7, 2009 Share Posted April 7, 2009 Guys, need a little troubleshooting help here......occasionally on startup, the 4L surges for a good 4-5 seconds around 2K rpms, then settles back down to a normal idle. Doesn't do it every time. Sticking IAC, maybe? It's not new, but it is clean (I tore the TB completely apart when I rebuilt prior to install). Jeff Link to comment Share on other sites More sharing options...
comancheman Posted April 7, 2009 Share Posted April 7, 2009 mine does the same thing sometimes. it seems to do it mostly on damp cold days. usually it stops after a few seconds but one day it wouldnt stop. i put it in drive and it was normal then i drove home about 15minutes put it in park and i went back up to around 2500k. i just shut it off and it hasnt happened lately. ive been blaming the IAC though Link to comment Share on other sites More sharing options...
Ed in North Ga. Posted April 7, 2009 Share Posted April 7, 2009 most times it IS the IAC, sometimes its the IAC`s bore- you have to clean both to get the full effect. Then theres the ever present vacuum leak- a TPS thats got a slight dead spot off idle (or several dead spots in most cases) a map sensor thats having a day moment...a fuel leakage through injectors before startup...an 02 sensor throwing an ultralean condition.... start easy, clean the IAC bore and retest- Link to comment Share on other sites More sharing options...
Geonovast Posted April 8, 2009 Share Posted April 8, 2009 My 2.5 does it once in awhile, hasn't caused any problems, so I haven't really looked into it. Both my Renix 4.0s did it too. Link to comment Share on other sites More sharing options...
mjeff87 Posted April 8, 2009 Author Share Posted April 8, 2009 I've got a new IAC that I picked up awhile ago, I'm going to swap it in this weekend and see if it makes any difference. Jeff Link to comment Share on other sites More sharing options...
