door and window seals
J.C. Whitney has them as a kit. 'Course, I just go to the wrecking yard, and pull them from a late model XJ. Even the window seals work, if you don't mind cutting them down, and the door seals are thicker, so the door seals much better, with ALOT less wind noise, and water intrusion.
