Rear cab harness light lead
The small light lead along the trans tunnel area of the rear cab wiring harness is to the 4wd shifter light, right? Anybody happen to know if the floor shifted auto mj's had a second light off the same couple of wires?
The socket should be a little bit bigger. Do you have a pigtail that "splits" into 2 sockets, or are you still using the single socket? If not, then go raid a XJ out in a junkyard for it. It is a snap to install.
