1990 Pioneer 4x4 Posted March 23, 2009 Posted March 23, 2009 Has anyone replaced their stock throttle body with a larger one? Hesco has a big bore 62mm throttle body, a bit expensive – I wonder if it’s worth the money... http://www.hescosc.com/shop.asp?action= ... catId=7972
Geonovast Posted March 23, 2009 Posted March 23, 2009 Nice upgrade if you have a stroker or planning on putting one in-otherwise not worth the money if you ask me.
GaruMJ Posted March 23, 2009 Posted March 23, 2009 A guy here in mexico open the stock throttle body in his machine shop to 62, 65 or 68mm, whatever you want he ask $100 for each throttle body. :brows:
GaruMJ Posted March 23, 2009 Posted March 23, 2009 And he does this spacers too, it depends the measure you want.
Ed in North Ga. Posted March 23, 2009 Posted March 23, 2009 Has anyone replaced their stock throttle body with a larger one? Hesco has a big bore 62mm throttle body, a bit expensive – I wonder if it’s worth the money... Remember, its a balance act. The more air you give it, the more gas it needs- most of us are already running lean. First thing I would grab with one of those is an adjustable MAP sensor and go up on the fuel pressure regulator....and it STILL isnt going to be worth it to me.
