Akula69 Posted March 10, 2009 Share Posted March 10, 2009 I'm probably not serching the posts correctly, but does anyone have a DIY thread on an easy way to replace the front axle control arm bushings? Thanks in advance. Jake Link to comment Share on other sites More sharing options...
ren Posted March 10, 2009 Share Posted March 10, 2009 Which bushings, exactly? The ones on the top of the axle or the ones in the control arms? The ones on the top of the axle you can change using a "C" clamp and a couple sockets. As for the ones in the control arms, mine are all aftermarket, so the bushings are different than the stock arms. Link to comment Share on other sites More sharing options...
Akula69 Posted March 10, 2009 Author Share Posted March 10, 2009 Which bushings, exactly? The ones on the top of the axle or the ones in the control arms? The ones on the top of the axle you can change using a "C" clamp and a couple sockets. As for the ones in the control arms, mine are all aftermarket, so the bushings are different than the stock arms. Daymn, I'm not thinking in complete thoughts today....top of the axle was the position I was referring to. Link to comment Share on other sites More sharing options...
Ibby Posted March 10, 2009 Share Posted March 10, 2009 I use a ball joint press for most bushings. Works well, comes with large enough cup sizes for pretty much any Jeep bushing. Link to comment Share on other sites More sharing options...
