How to hook up power windows?
Easy enough if you're electrically savvy, but just time-consuming.
There's an article in the January 2009 issue of JP Magazine that documents the procedure on my MJ. And here is a wiring chart from that article that may help you out.
Well..... I started to put the driverside door on today and its not fitting right. It doesnt shut all the way, theres about 6inched still left for the door to close. Did I put them on right? I took the bolts off the door and just swapped the doors. Should I have swapped the hinged as well? I wanna make sure I fix this before starting on my passenger side.
