hogelectra Posted February 16, 2009 Posted February 16, 2009 Ok putting my new 88 under my MJ and I need to make sure I understand. Some details 1. leaving leaf springs under axle 2. the measurements should be made with axle under weight of vehicle I would have to put spring perch on the axle and bolt it down and lower vehicle. Connect driveshaft. Take my measurement of both drive-shaft and differential angles. Raise vehicle back up and adjust differential angle. Lower vehicle back down and measure again. Repeat until angle it correct and tack weld and remove for final welding Image Not Found
BLHTAZ Posted February 16, 2009 Posted February 16, 2009 When we did mine on the YJ, we bolted everything in place, but not so tight that it couldn't be moved, set it on the ground, hooked up the drive shaft and then used a small floor jack to push the pinion up until we had it where we wanted it and tacked the perches in place. It took all of about 5 minutes to do. There is no need to keep picking it up and putting it back down again. :cheers:
hogelectra Posted February 17, 2009 Author Posted February 17, 2009 use of a floor jack - that's something I might have thought of but might not thanks I have to go find a u-joint that will accommodate the 1330 on the 8.8 side and 1310 on the axle side. I'm told that was a common thing on some Ford trucks straight from the factory - so it shouldn't be hard
jbhill Posted February 17, 2009 Posted February 17, 2009 measure the angle of the output flange on the trans/tcase(usually around -2 or -3) raer pinion should be around +2 or +3 a degree wheel is your friend.
redneck23ms Posted February 17, 2009 Posted February 17, 2009 use of a floor jack - that's something I might have thought of but might not thanks I have to go find a u-joint that will accommodate the 1330 on the 8.8 side and 1310 on the axle side. I'm told that was a common thing on some Ford trucks straight from the factory - so it shouldn't be hard you can get a different companion flange for your driveshaft that takes a 1310 u-joint. the one i have came off of a ranger.
hogelectra Posted February 18, 2009 Author Posted February 18, 2009 but couldn't I just use a 1310/1330 u-joint
CWLONGSHOT Posted February 18, 2009 Posted February 18, 2009 use of a floor jack - that's something I might have thought of but might not thanks I have to go find a u-joint that will accommodate the 1330 on the 8.8 side and 1310 on the axle side. I'm told that was a common thing on some Ford trucks straight from the factory - so it shouldn't be hard I'm almost positive I have a spare flange. I would just need to find it. Incase you strike out... As for the angle I always set it so its just pointing down from straight. So under power when the springs torque flex its straight pointing at the back of the Tcase. CW
BLHTAZ Posted February 18, 2009 Posted February 18, 2009 As for the angle I always set it so its just pointing down from straight. So under power when the springs torque flex its straight pointing at the back of the Tcase. CW That is exactly the method that I have always used too and it has never been a problem. :thumbsup:
