Rear Axle Offset
Hello, first post. I recently bought a 91 shortbed, 4cyl, 5speed, Dana 35. I was switching tires on the rear and found the right rear tire haS been rubbing on the frame, so I took some measurements and the right rear is only about 1" away from the frame and left rear is about 2" away from frame, tire size is P235/75/15 on stock rims, any ideas, is this normal???
No
Check al your spings, shackles and bushings. Post back if everything is good.
