blusteve Posted February 8, 2009 Share Posted February 8, 2009 Removed my battery tray today and found a large rusted area where battery acid had eaten the metal, large hole. What is the best way to repair, will cherokee late model inner fenders fit, if so can these still be bought from MOPAR. My commanche is a 91 Link to comment Share on other sites More sharing options...
Pete M Posted February 8, 2009 Share Posted February 8, 2009 pics? Link to comment Share on other sites More sharing options...
Sir Sam Posted February 9, 2009 Share Posted February 9, 2009 Removed my battery tray today and found a large rusted area where battery acid had eaten the metal, large hole. What is the best way to repair, will cherokee late model inner fenders fit, if so can these still be bought from MOPAR. My commanche is a 91 you can replace that whole bit....... replaced it on many cherokees, any 87+ will work for the donor piece. should cost less then $30 at a junkyard, you can sawsall it off, then remove the spot welds and reweld. Link to comment Share on other sites More sharing options...
