4x4 swap drive line length
i swapped my long bed 4cy comanche to 4x4 and its 56'' inches from the tail of the tcase to the u joint clamp. i am just wondering if anyone knows from an other vehicle a good drive line that will work so i can have it cut down
and I'm not useing a slip yoke eliminator
I ran the big driveshaft for years without issues. Just make sure you're shortening the non-isolator end (i.e. keeping the rubber isolator) and when reinstalled, the rubber isolator stays at the axle end.
Big shaft that brings up some of my own questions. I noticed that my drives haft is really large - bigger then what I have seen on Cherokee I run with. I saw a vendor tag on it so I know it is an after market add on. Are these better then others? Also when I finally go to a DANA44 can the driveshaft be shorten to fit?
