Making 97+ XJ seats work
I know that its pretty strait forward to make the earlier 93 down XJ seats fit in the MJ, how hard is it to make the 97+ XJ seats from a 2 door work?
Different mounting points on the floor, with a little bit of steel, a welder and some fab time it would be easy enough to swap them over.
it was easy for me.. image_209027.gif I just bent the 97+ brackets to go onto the floor and drilled some new holes. The location of the fronts was close to the original location, so i got one hole to line up. Bad thing about mine is they have a small forward lean. If you do what Bo did to his seats you won't have that problem. Check his build thread. "Onyx"
Sorry but this is the best pic i have of mine. I scored 2-door seats so i have the cool forward tilt.
