Removing Doors
To get the doors off i can see that you need to take off two brackets (one on top and one on bottom) and instead of taking off all of the torx bolts, i could hammer out the pin thats holding the bracket to the door. I gave it a little tap earlier today and it didn't seem like it wanted to budge at all. So do you think if I sprayed some penetrating oil on it or something and just pound the heck outta it :brows: could I get it loose?
Those things don't beat out to good. Maybe drillin them but its a tight spot. I cut the bottom part of the hinge off and worked the doors off like that then drilled them out and replaced the hinge pins. I was making mine removable so i didnt car to cut that off.
Cole
