Novak T-Case Shifter Install?
I know there were a couple guys on here that had installed a Novak T-Case replacement shifter...While I'm installing it on my TJ and not the MJ, I thought I would still ask... beyond the obvious AND TOTAL pain in the butt of bending the shifter cane so I can acutally shift the t-case into all the gears (which I'm no where near close with yet), did anyone have any vibrations/buzzing coming the from the shifter assembly itself (not the cane hiting the tub opening or anything?). I've check the bolt between the main bracket and the arm and the bolts at the end of the threaded rod linkage assembly...
The only good thing that has come out of me messing with this thing for like a month now is that I can get the RE Long Arm Belly Pan dropped and Front Driveshaft off all in about 10 minutes flat...
Sw2
  • 4 weeks later...
