SuperWade2 Posted January 18, 2009 Share Posted January 18, 2009 I know there were a couple guys on here that had installed a Novak T-Case replacement shifter...While I'm installing it on my TJ and not the MJ, I thought I would still ask... beyond the obvious AND TOTAL pain in the butt of bending the shifter cane so I can acutally shift the t-case into all the gears (which I'm no where near close with yet), did anyone have any vibrations/buzzing coming the from the shifter assembly itself (not the cane hiting the tub opening or anything?). I've check the bolt between the main bracket and the arm and the bolts at the end of the threaded rod linkage assembly... The only good thing that has come out of me messing with this thing for like a month now is that I can get the RE Long Arm Belly Pan dropped and Front Driveshaft off all in about 10 minutes flat... Sw2 Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 18, 2009 Share Posted January 18, 2009 If it uses solid joints (heims) on the linkage, any driveline vibration will be transmitted through it. Link to comment Share on other sites More sharing options...
SuperWade2 Posted January 18, 2009 Author Share Posted January 18, 2009 DirtyComanche said: If it uses solid joints (heims) on the linkage, any driveline vibration will be transmitted through it. Si' Link to comment Share on other sites More sharing options...
jeepcoma Posted February 12, 2009 Share Posted February 12, 2009 Sw2 if you give up on that linkage install, I can take it off your hands for you :D My stock linkage could use a good replacement. Link to comment Share on other sites More sharing options...
SuperWade2 Posted February 12, 2009 Author Share Posted February 12, 2009 Nah I got it.... I got it close and had the shop I take the TJ too do some final Adjustments... Link to comment Share on other sites More sharing options...
