BookspanS Posted January 12, 2009 Share Posted January 12, 2009 I have shift on the column, and I can't seem to get the bezel around the gauges and radio out. How do I get it around the shifter? Link to comment Share on other sites More sharing options...
jtdesigns Posted January 12, 2009 Share Posted January 12, 2009 Try dropping it in low. might have to kinda flex it till it pops out. Link to comment Share on other sites More sharing options...
BookspanS Posted January 12, 2009 Author Share Posted January 12, 2009 It also doesn't want to come past the rise that the column shift creats on the actual comumn right in front of the bezel Link to comment Share on other sites More sharing options...
jtdesigns Posted January 12, 2009 Share Posted January 12, 2009 pull the top out and flex it till it pops out. Sometimes you have to kinda force them to come out. Link to comment Share on other sites More sharing options...
BookspanS Posted January 12, 2009 Author Share Posted January 12, 2009 ok, thx Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 12, 2009 Share Posted January 12, 2009 Unless you loosen the column to drop it down a little, you will have to do as JT said and use a little "persuasion" and hope that you don't end up with it in multiple pieces. I don't have the column shift, but I have had mine out about 7-8 times now and I grit my teeth every time hoping that it doesn't break. Link to comment Share on other sites More sharing options...
jtdesigns Posted January 12, 2009 Share Posted January 12, 2009 Unless you loosen the column to drop it down a little, you will have to do as JT said and use a little "persuasion" and hope that you don't end up with it in multiple pieces. I don't have the column shift, but I have had mine out about 7-8 times now and I grit my teeth every time hoping that it doesn't break. Thinking about it breaking reminds me to tell you that if you let your truck warm up pretty good it'll be less likely to break, then if everything's cold.. Plastic is brittle when cold. :smart: Link to comment Share on other sites More sharing options...
BookspanS Posted January 12, 2009 Author Share Posted January 12, 2009 Will it still warm up if my heater don't work? Link to comment Share on other sites More sharing options...
deziped Posted January 12, 2009 Share Posted January 12, 2009 Just remove the two nuts holding the column up & let it drop. It makes removal a lot simpler. Why risk breaking stuff. Link to comment Share on other sites More sharing options...
jtdesigns Posted January 12, 2009 Share Posted January 12, 2009 Just remove the two nuts holding the column up & let it drop. It makes removal a lot simpler. Why risk breaking stuff. or you could do that. I've never had to do that, but then again I'm whipping a 5spd. Link to comment Share on other sites More sharing options...
