Axle seal recommendations?
I bought some axles from Twisty here on the board and they've got some weeping outer seals I'd like to replace before installing them. Any recommendations for brands? I've found sets from National Oil Seal and Timken among other generic brands.
I know there are differences between front left and right for CAD axles, but it's for a D30 with upgraded 1-piece axles, so are the outer left and right seals interchangeable? The rear is a D44, I'm pretty sure the outer seals are interchangeable but is there a preferred brand or piece?
This is a write up on the shaft conversion, but it has the part numbers for the seals you need in it. It will also show you how to go about changing them as it is not a real simple job to do because you have to take the differential out if the housing and change them from inside.
Click Here for the write up.
Thanks for the link! The solid axle conversion had already been done, and the leak is only on the driver's side outer seal, so it should be far less troublesome. I was considering just doing them all while I had the chance but time crunch will probably mean I only get to fix the ones that are leaking.
Ok thanks.
I'm looking at Advance Autopart's site, they list three two part numbers for the front:
Part No.
710068
National Oil Seal
Front Axle; Left Disconnect or Non-Disconnect; Right Non-Disconnect; Spicer 30-AF 7.125" R.G.;
Part No.
710202
National Oil Seal
Front Axle; Right; Spicer 30-AF 7.125" R.G.; Disconnect
Obviously I need the 710068 for the front left (which is the only one leaking, so maybe I'll just fix that now), but would I still use the Disconnect seal for the right or Non-Disconnect (or would it not matter?)
They also list 3 SKF oil seals:
Part No.
11899
SKF Oil Seal
Axle Shaft Seal: Front; Four Wheel Drive (4x4); Without Disconnect Axle; 2 Required Per Vehicle
Part No.
15843
SKF Oil Seal
Axle Shaft Seal: Front; Right Hand; 2.131 Inch O.D.; Four Wheel Drive (4x4); Disconnect Axle; 2 Required Per Vehicle
Part No.
16083
SKF Oil Seal
Axle Shaft Seal: Front; Right Hand; 2.286 Inch O.D.; Four Wheel Drive (4x4); Disconnect Axle; 2 Required Per Vehicle
Are these worth twice the price over the national oil seal version? How would I know which I need?
Note: advance is just down the street from where I work and can walk there during lunch, which is the only reason I'm checking parts there (they don't have any in stock anyway). I'm also close to Autozone, Napa, and e-distributors; I just need the seals by Monday to get going on this.
Thanks guys
Ok, so I think I've got this figured out. For the front, I need seals for that fit the non-disconnect version (because they are 297 axle shafts in a regular disconnect housing), which are interchangeable left and right. That would be part number 710068 or equivalent.
For the rear though there's more confusion (for me anyway). Are there four seals for this, two inner (to hold the gear oil in the pumpkin and out of the tubes) and two outer (to keep dirt out of the tubes)?
Autozone lists three:
Timken / Wheel Seal - Rear
9912S
$11.99
Application:
Dana/Spicer 44 axle
Note:
Outer
481837
$4.99
Application:
Dana/Spicer 44 axle
Note:
Inner
2689S
$17.99
Application:
Dana/Spicer 44 axle
I think the inner and outer makes sense, but what's this 2689S part for? These are the only details listed, there was no other information I could find.
Well I had zero luck with their web site. I think what might be happening is that what they are calling the inner "seal" is actually the retaining ring that gets pressed on to the axle for some non c-clip applications. Chrysler actually made the same mistake with WJ listings at one point in time. They called the retaining ring a snap ring.
