ocskipper Posted December 15, 2008 Share Posted December 15, 2008 I have searched everywhere, including my haynes manual for a detailed description of what this is. I am having problems with the lines going in, I think it is just a connector but am unsure. Reffering to the picture below, here is my problem... #1. The line broke off right outside of the inlet and i can't figure out how to install the line. It is a very tight fit and the remainder of the broken peice is still inside which creates a wonderfull whistling sound while driving. The vaccuum is comming out of the port and I have no idea what it is for. Any explinations and fix ideas?? :hmm: #2. Same problem with this line. I have used a little rubber connector as a temporary fix. No idea what it is for, but can't get the line to re-insert. #3. This I know is the MAP sensor line. I included it as a reference but it also is loose and falls out at times. I also have a light comming on as I shift from gears 1 through 3. It doesnt light up in 4th and turns off when I depress the clutch and when I first engage in gear. I don't know what the light means, nothing on it in the haynes manual. Thanks for the help... :cheers: :USAflag: Link to comment Share on other sites More sharing options...
ocskipper Posted December 15, 2008 Author Share Posted December 15, 2008 I have searched everywhere, including my haynes manual for a detailed description of what this is. I am having problems with the lines going in, I think it is just a connector but am unsure. Reffering to the picture below, here is my problem... #1. The line broke off right outside of the inlet and i can't figure out how to install the line. It is a very tight fit and the remainder of the broken peice is still inside which creates a wonderfull whistling sound while driving. The vaccuum is comming out of the port and I have no idea what it is for. Any explinations and fix ideas?? :hmm: #2. Same problem with this line. I have used a little rubber connector as a temporary fix. No idea what it is for, but can't get the line to re-insert. #3. This I know is the MAP sensor line. I included it as a reference but it also is loose and falls out at times. I also have a light comming on as I shift from gears 1 through 3. It doesnt light up in 4th and turns off when I depress the clutch and when I first engage in gear. I don't know what the light means, nothing on it in the haynes manual. Thanks for the help... :cheers: :USAflag: Link to comment Share on other sites More sharing options...
aemsee Posted December 15, 2008 Share Posted December 15, 2008 It is a "look up" light :D . That is a stupid up shift light. The ultimate in idiot lights. Lets you know when to shift. You could get rid of that plastic connector and splice your lines together with vacuum hose. Especially the MAP hose. Link to comment Share on other sites More sharing options...
ocskipper Posted December 15, 2008 Author Share Posted December 15, 2008 You are sure that the plastic connector holds no other purpose? I would like to eliminate it as it just seems like a pain, but don't want any complications. I figured the light was something as dumb as that, wish I could get rid of it. On a side note...could a bad or going bad headlight swith effect my dome lights. One works only when I adjust it at the actual lense by moving it up or down but not at the switch, and the other doesnt work at all. Link to comment Share on other sites More sharing options...
oldrusty Posted December 16, 2008 Share Posted December 16, 2008 that entire connector assembly is available from napa. I don't have my books here theyre all at the shop but if you can't find one I can get the part number Link to comment Share on other sites More sharing options...
aemsee Posted December 16, 2008 Share Posted December 16, 2008 MJ interior lights are notorious for their crappyness (new word). Most upgrade to something else. Check for related posts. Link to comment Share on other sites More sharing options...
ocskipper Posted December 16, 2008 Author Share Posted December 16, 2008 Thanks for the help, i will check napa for that part and cost. I might just eliminate the part, the more I looked at it today the more i feel it is pointless. You will probably see a post up soon with some wiring questions on some new interior lights! Thanks guys. Link to comment Share on other sites More sharing options...
Jacobs Posted December 16, 2008 Share Posted December 16, 2008 Yep, just hack that thing out of there. All the lines going to it just pass in and out, with no crossovers internal to the piece so nothing to worry about. Link to comment Share on other sites More sharing options...
ocskipper Posted December 16, 2008 Author Share Posted December 16, 2008 I got the connector out and connected all the lines directly. The manche is purrrring now. Thanks for all the help!! :cheers: :USAflag: Link to comment Share on other sites More sharing options...
