IDXJ Posted December 15, 2008 Share Posted December 15, 2008 I am going to replace the 2 piece shaft on my '88 and other than the shaft itself all I will need is a new inner seal correct? Anyone done this? I guess that both sides would use the same seal too? TIA. Dave Link to comment Share on other sites More sharing options...
IDXJ Posted December 15, 2008 Author Share Posted December 15, 2008 I am going to replace the 2 piece shaft on my '88 and other than the shaft itself all I will need is a new inner seal correct? Anyone done this? I guess that both sides would use the same seal too? TIA. Dave Link to comment Share on other sites More sharing options...
GaruMJ Posted December 15, 2008 Share Posted December 15, 2008 I hope this help you. :banana: http://www.stu-offroad.com/axle/yjd30co ... vert-1.htm Link to comment Share on other sites More sharing options...
GaruMJ Posted December 15, 2008 Share Posted December 15, 2008 There is a lot of info in this site :brows: .Good luck! http://www.jeepforum.com/forum/showthread.php?t=89273 Link to comment Share on other sites More sharing options...
aemsee Posted December 15, 2008 Share Posted December 15, 2008 Question. What is the reason for putting the outer seal back in/ replace it when doing this swap? Link to comment Share on other sites More sharing options...
IDXJ Posted December 15, 2008 Author Share Posted December 15, 2008 Thanks for the links. I can see no reason to put the outer seal in. The one piece axle diameter is quite a bit smaller than the sealing area on the old shaft so, it won't do anything. Link to comment Share on other sites More sharing options...
