97+ door windows
You mean something like this?
http://www.comancheclub.com/forums/viewtopic.php?f=7&t=6668&p=64602#p64602
It's possible, but time-consuming to set up. You need to grind out the vent window 'bridge'. I had a set of 'new' doors I compared bolt hole locations to, and had some spacers made to achieve the correct depth of the various attachments. You'll also need the 'newer' trim pieces as well as the front glass channel (which is cut out of the 'new' doors). I also haven't hung an interior on mine yet so there may be even more problems I haven't encountered yet. But, I have ran the windows up and down. :yes:
