blusteve Posted December 10, 2008 Share Posted December 10, 2008 What is the difference in the TJ vs. Mj Front coil springs is it height difference or size(round) Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 10, 2008 Share Posted December 10, 2008 They are interchangeable, but the TJ springs are a little lower spring rate so they will not give as much lift on an MJ as they do the TJ. From what I have seen on here in other threads, the TJ coils typically give about 1.5" less lift on an MJ than they are rated to give a TJ. Link to comment Share on other sites More sharing options...
tjbliley Posted December 10, 2008 Share Posted December 10, 2008 What taz says is about right. I am running 4" ?TJ springs on the front and got about 2.5" of lift from them. This works well with a AAL and Chevy Drop Shackles in the back to give you a nice rake. This will allow you to clear 31's with the right wheel backspacing. Link to comment Share on other sites More sharing options...
mjeff87 Posted December 10, 2008 Share Posted December 10, 2008 X3 I'm running 5.5 TJ coils, gave me @ 4-4.5" lift. Jeff Link to comment Share on other sites More sharing options...
