Reviewview Mirror Button Removal?
Common wisdom is that attempting to remove the bonded button by mechanical means will likely result in broken windshield.
Sooo, has anyone had success removing this bonded little bugger using solvent? What solvent? It is mis-positioned far too
low for my preference. It just laughs at acetone, laquer thinner, toluene, and 190 proof alcohol. Suggestions? Thanks!
Heat gun on very low setting, to soften the adhesive, and a razor scraper to work the button off. isopropyl alcohol to clean the adhesive.
And of course........pick up a mounting kit and follow the directions :D
JT......he wants to raise it up from the current position.
oops... I forgets, I failed Proof-reading class!! :teehee: I usually pop them off not meaning too!!!
:no:
