james750 Posted December 7, 2008 Share Posted December 7, 2008 I know that it is pretty extensive to put power windows off of a 97+ into an mj but what about putting some in from an older XJ? Is the wiring already their and its plug and play? I would want to find new 4 door door panels or full doors and then the handles off of a 2 door so that it would look right (no buttons for 4 door). Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 7, 2008 Share Posted December 7, 2008 No, there are no provisions for wiring with the manual window models. I've done this mod, and used aftermarket regulators (because the OEM power regulators are junk) with the stock XJ/MJ 2-door switches. It's pretty simple to do, just make sure when you get the switch assemblies from the yard (or whererever) get the power window switch connectors with the wiring pigtail. Then you can fab your own inner door wiring and cross body harness. If you need a wiring diagram let me know via PM and I can send it as an attachment. Link to comment Share on other sites More sharing options...
