88swampedmj Posted July 1, 2006 Share Posted July 1, 2006 well my power steering pump has leaked out all the fluid awhile ago and ive just been drivin without power steering pretty much....i wheeled without it and ill never do that again...so how hard is it to change a powersteering pump on a 4.0 comanche? ....are the pumps expensive?? Link to comment Share on other sites More sharing options...
Cabz Posted July 1, 2006 Share Posted July 1, 2006 Pulling the pump is a PITA but if you remove the airbox and electric fan it is a lot easier to get too. as far as expence I'm thinking about $75.00 depends on if you get it with or without the resivior and pulley . Link to comment Share on other sites More sharing options...
ROADLESS Posted July 1, 2006 Share Posted July 1, 2006 The hardest part is getting the pulley off the pump. To save a little coin, after you remove the pump take it to the parts store and borrow their P.S. puller and remove the pulley right there. Your new or rebuilt pump should come with an install tool (basically a threaded bolt and nut) that you can use to put the pulley back on. The pulley is alot harder to take off, but real easy to put back on. Also, make sure and replace the o-ring on the high pressure side, it should also come with the pump. Good Luck :popcorn: ! Link to comment Share on other sites More sharing options...
88swampedmj Posted July 2, 2006 Author Share Posted July 2, 2006 thanks guys Link to comment Share on other sites More sharing options...
