Front height without flares
No, but I can give you the official, factory tech bulletin method of measuring:
Top of axle tube to underside of frame rail, straight up. Be sure to measure from the actual tube, not from any brackets or the disconnect housing. 2WD should be 6-3/4" plus or minus 1/2". 4WD should be 7-3/4" plus or minus 1/2".
