flint54 Posted November 17, 2008 Share Posted November 17, 2008 Ok, just how do you UN spot weld something, without tearing the metal? I'm replacing the drivers front seat support stamping, and, in addition to the rivet, there are two large spot welds per pad. Chiseling is causing cracks, and it seems that drilling these would leave not much material left. Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 17, 2008 Share Posted November 17, 2008 Drilling is the only way I have ever known/heard of, but I am not real familiar with exactly what you are doing so my advice is not particularly dependable here. ;) Link to comment Share on other sites More sharing options...
HellCreek Posted November 17, 2008 Share Posted November 17, 2008 Search eBay for "spot weld cutter". They are special step drills that cut the upper layer of sheet metal and leave the bottom layer to weld to later. I bought a set, and they work great. Tom Link to comment Share on other sites More sharing options...
summerinmaine Posted November 17, 2008 Share Posted November 17, 2008 Ok, just how do you UN spot weld something, without tearing the metal? I'm replacing the drivers front seat support stamping, and, in addition to the rivet, there are two large spot welds per pad. Chiseling is causing cracks, and it seems that drilling these would leave not much material left. Do you really need to re-weld to make it secure? Wouldn't bolts do the job. I used this link to guide me through my recent seat replacement, but fortunately didn't need to modify the brackets at all. Link to comment Share on other sites More sharing options...
Sir Sam Posted November 17, 2008 Share Posted November 17, 2008 napa and harbor frieght both carry spot weld cutters. Link to comment Share on other sites More sharing options...
jbhill Posted November 17, 2008 Share Posted November 17, 2008 rotabroach spot weld cutters ftw. Link to comment Share on other sites More sharing options...
