Redramman Posted November 17, 2008 Posted November 17, 2008 Still working on the AX5.I'm taking the trans apart ,Tail(Adaptor housing) is off,bell housing off, front bearing retainer and 4-snap rings off.Trying to separate case from Intermediate plate but it only moved 1/8" .I can see some broken parts in botom of case but it seems to be hanging up on one of the front bearings.Are the bearings suposed to come off first??? or are holes in case made to slide bearings through???. In the Chilton book it looks like they slide through once all snap rings are off.
Geonovast Posted November 17, 2008 Posted November 17, 2008 Nope, bearings stay on the shafts. You just gotta wiggle it off. There's nothing else holding it on.
Redramman Posted November 18, 2008 Author Posted November 18, 2008 Thanks the bearings fit realy tight ended up hitting the shafts with plastic tiped hammer alternating between the two to sort of wiggle them with a little extra force.
