Advise for trans swap(AX-15 to AX-15)
I'm new in the jeep stuff, my trans ax-15(MJ 89) is dripping oil from the slave cylinder. I want to change the trans with another AX-15(XJ 90) and put new clutch+slave+master. Do you have any suggestion for the new parts and where i can buy them ?
:Canadaflag:
I highly recommend buying your hydraulic clutch components from your local Jeep dealership. Especially with the slave cylinder. Don't go cheap on it or you may have to replace it again in short order. Plenty owners have. :( It's totally worth the extra cost up front to not have to drop the trans again. :thumbsup:
Send a PM to BLHTAZ as he works at a dealership and may be able to get your parts a bit cheaper.
