I finally got around to checking the extent of the damage of the passenger side motor mount breaking. Looking from the passenger wheel I see that 3 bolts have sheared off with the shaft of the bolts still in the holes on the side of the engine block.
Before I get to work on tryign to get them out I was wonderign if you guys knew what size bolts these were so I can pick some up.
Thanks,
-Will
