xj_dummy Posted October 11, 2008 Posted October 11, 2008 I went to take out the old temp sender and this happened, Image Not Found Image Not Found Damn thing broke off flush with the head. What do I do Now? Is there anywhere that I can temporarily add a temperature unit till I get this fixed? At least it dosent apear that it leaks. The oil is leaking from the valve cover gasket.
Wildman Posted October 11, 2008 Posted October 11, 2008 If the old one is not leaking, possibly go with the HO thermostat housing, and make it a permanent fix :dunno: http://info.rockauto.com/RB/902-306-003.jpg
Wildman Posted October 11, 2008 Posted October 11, 2008 Sorry......I was thinking of a 4.0......but I just cross checked the part # and it's the same......for a 2.5 or 4.0. FOUR SEASONS Part # 85180 $12.81 And Advance Auto parts show it in store stock, around me, so it should be a store stock item in your near by auto parts store.
xj_dummy Posted October 11, 2008 Author Posted October 11, 2008 Thanks for the thought but I want to see what others might say. How hard would it be to remove the old one?
Wildman Posted October 11, 2008 Posted October 11, 2008 Drill / easy out......maybe a little heat to brake the rust weld. Chase it with a tap.
xj_dummy Posted October 11, 2008 Author Posted October 11, 2008 Drill / easy out......maybe a little heat to brake the rust weld. Chase it with a tap. Um ok, Gulp Ill try a little later. thanks. Do you want to help me do this? How long of a drive is it from NY to Ca?
Wildman Posted October 11, 2008 Posted October 11, 2008 Yea, no problem ;) Bring it by the shop tomorrow around 8:30 :D I just mapquest it, and it's only about 4 inches on the map :brows:
