MrSimon Posted October 6, 2008 Share Posted October 6, 2008 I am going to do a driveway paint job on my MJ. I'm not looking for it to be perfect, just half way decent. I'm gonna sand the whole thing down before painting. I don't want to sand the whole truck more than twice. What two levels of grit would you guys recommend I use? Link to comment Share on other sites More sharing options...
pingpong Posted October 6, 2008 Share Posted October 6, 2008 It depends on the shape of your current paint job, and how different the color you are going to use. If I was going the same color, or close to it, I would just scuff the paint, using a 240 or 260 grit. Making sure to blow it down and wipe it before sparing any of it. If you are doing a drastic color change like blue to white.. well then I would definately use a primer, and scuff the primer with a 600 grit. Link to comment Share on other sites More sharing options...
garmj Posted October 6, 2008 Share Posted October 6, 2008 I am doing a driveway paint job on mine and I am using 220 grit on a DA and going over that with a fine scuff pad, I use the scuff pad to get the edges and tight areas where you can't get the sandpaper to go.[/img] [/url] Link to comment Share on other sites More sharing options...
