Help Replacing clutch master cyl.
I'm Replacing clutch master cyl. today. Need to switch resevoir to new master,do I just clamp it on without any type of sealer? Also will any name brand brake fluid work? synthetic fluid?? .The main reason I ask is someone posted about using only Casteroil brand?
yeah that brand name thing is all crap. dot 3 or 5 is what i would run. but never mix the two.dot3 is thinnest so it will be "easier" to push the pedal in. dot5 won't soak up water like dot3 & 4. hose clamp the resi to the master. bleed from the slave. unless.... i guess you could reverse bleed it... anyone ever tried this?
