ICEBOX Posted October 1, 2008 Share Posted October 1, 2008 I need a exploded view of my front axle dana 30 with disco anyone have a link ?? Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 1, 2008 Share Posted October 1, 2008 Try this and see if it's what you are looking for... Link to comment Share on other sites More sharing options...
ICEBOX Posted October 1, 2008 Author Share Posted October 1, 2008 Yes it is but, do you have the lower half of that photo ? i need the num,bers for the bearing Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 1, 2008 Share Posted October 1, 2008 The bearings are not in that picture. Here is the one that shows them... Link to comment Share on other sites More sharing options...
ICEBOX Posted October 1, 2008 Author Share Posted October 1, 2008 Ok what I am trying to find out is what 35 and 40 are. I replace the seal on the whel side of the disconect. But I didn't see anythingin that side to suport the axe shaft Link to comment Share on other sites More sharing options...
mjdoa Posted October 1, 2008 Share Posted October 1, 2008 Icebox,I'm not at work so going by memory. I work in Mopar parts,as does BLHTAZ. #35 and 40 are a seal and slinger. There is a bearing a little further in,not in either pic. It's on the outer part of the inner shaft. Your question I think is what supports the inner part of the outer shaft.The outer shaft has a bearing inside a hole in the end of the shaft.Small tit on the inner shaft rides in it. The other end is held up by the wheel bearing. So what holds the inner end of the outer shaft?Nothing,really. Believe it or not.Nothing between the wheel hub and the end of that shaft.What keeps the u-joint from wobbling around? Again,nothing.I freaked when I learned that. Suggestion?Dump it,get a non-disconnect axle.I did. Most everyone else has. I hope that's your answer and is understandable.Maybe one of the other guys can be a litle more eloquent. Link to comment Share on other sites More sharing options...
ICEBOX Posted October 1, 2008 Author Share Posted October 1, 2008 hEY THANK YOU FOR THE INFO ! Link to comment Share on other sites More sharing options...
mjdoa Posted October 1, 2008 Share Posted October 1, 2008 Help at all? I'm not a writer,by any means,sorry. If you want BLHTAZ can probably post up the pics of the shafts with the bearings in it,I have not figured out how to. He explained how to do it,but I'm either too thick or too computer dumb.I can't even get an avatar to work. :roll: Link to comment Share on other sites More sharing options...
