Kenosha Warrior Posted September 19, 2008 Share Posted September 19, 2008 Modified:: I have no Highbeams still, Pete, anymore insight on that switch you mentioned? I now have an indicator light on the dashboard but still no highbeams, is there any possible way a wire is broken or am I just sporting some dud bulbs? Link to comment Share on other sites More sharing options...
Pete M Posted September 19, 2008 Share Posted September 19, 2008 The turn signal stalk pushes on a bar that runs down the steering column to a switch near the bottom. I never had brights on my 88 until one day I found out about that switch. Turns out it was just misaligned. A bit of screwing around with it got me my brights back. :D Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted September 19, 2008 Author Share Posted September 19, 2008 Where's that switch located Pete? I'm heading up to the truck in a bit so Ill look for it./ Link to comment Share on other sites More sharing options...
Pete M Posted September 19, 2008 Share Posted September 19, 2008 Where's that switch located Pete? I'm heading up to the truck in a bit so Ill look for it./ It's strapped to the drivers side of the column, down by your feet. Follow the silver bar running down from the turn signal stalk. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted September 29, 2008 Author Share Posted September 29, 2008 bummpittay for modified first post. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted September 29, 2008 Author Share Posted September 29, 2008 Got'er. The harness on the headerpanel is tuckerd. Swapped in the original one and we're all lights go! Link to comment Share on other sites More sharing options...
