I want to change my tailgate handle and I was wondering what to watch for once I remove the three bolts holding the handle, how are the latches connected to the handle? Also I read some old posts that said 83-92 s10 handles are the same, but then someone said they had a problem with the bolt location being different, anybody know if that's so?
It's pretty strait forward. I replaced mine awhile back and it was really simple switch with nothing special to worry about. I believe you need a torx bit though. Don't know the size. I guess be careful to not drop the lever thingies inside of the tailgate when you remove the handle.
I don't know anything about s-10 handles working, but I'm sure someone could grab one from a junk yard for ya.
EDIT: The bolts are Torx 30 size
The actuating rods just snap onto the handle mechanism. You'll see how it works when you start working on it. Lift the handle and look inside the tailgate.
