DirtyComanche Posted September 9, 2008 Share Posted September 9, 2008 I'm looking for any new ideas. Or old ideas. Throw out whatever you've got. I'll get the ball rolling with one. High mount alternator - I have not tried this, but apparently the 2.5L bracketry will allow a 4.0L alternator to be mounted in place of the A/C compressor. Why mount it high? So it doesn't injest mud, which will kill the slip rings and bearings. Link to comment Share on other sites More sharing options...
ORCA Posted September 9, 2008 Share Posted September 9, 2008 I'm looking for any new ideas. Or old ideas. Throw out whatever you've got. I'll get the ball rolling with one. High mount alternator - I have not tried this, but apparently the 2.5L bracketry will allow a 4.0L alternator to be mounted in place of the A/C compressor. Why mount it high? So it doesn't injest mud, which will kill the slip rings and bearings. Woah really? Do you have any more info on this? i've got a busted A/C condensor that i've wanted to get rid of for the longest time... Link to comment Share on other sites More sharing options...
possum Posted September 9, 2008 Share Posted September 9, 2008 Remote reservoir power steering pump. I have mine mounted beside the rad to help keep it up and out of the water. You can generally find these on mid-eighties full size vans. Don't know how hard it would be to fab one on a 4.0 as I run a chevy 5.7 Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 11, 2008 Author Share Posted September 11, 2008 I'm looking for any new ideas. Or old ideas. Throw out whatever you've got. I'll get the ball rolling with one. High mount alternator - I have not tried this, but apparently the 2.5L bracketry will allow a 4.0L alternator to be mounted in place of the A/C compressor. Why mount it high? So it doesn't injest mud, which will kill the slip rings and bearings. Woah really? Do you have any more info on this? i've got a busted A/C condensor that i've wanted to get rid of for the longest time... I've told you all I know. Apparently it works, but I have no pictures to back it up. I'm going to look into it along with some of the other options. Other options: http://naxja.org/forum/showthread.php?t=956261 http://www.jeepforum.com/forum/showthread.php?t=540166 I'm currently looking for an option that will allow me to put the A/C compressor somewhere else - I want it for OBA. Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 11, 2008 Author Share Posted September 11, 2008 Remote reservoir power steering pump. I have mine mounted beside the rad to help keep it up and out of the water. You can generally find these on mid-eighties full size vans. Don't know how hard it would be to fab one on a 4.0 as I run a chevy 5.7 The pump is probably different... But if a guy wants some bling, PSC ( http://www.pscmotorsports.com/ ) offers a high-pressure/high-flow pump (remember my thread in the how-to on P/S pump mods, they do that basically) that has an AN/JIC fitting for the inlet instead of the integral reservoir. They also sell nifty aluminum remote reservoirs which are baffled to prevent pump cavitation while off-camber or hitting big air. PSC has overdrive pulleys too (more turning power at idle) and cooler setups. Here's another one for increased power-steering reliability; add a filter. An el-cheapo hydraulic filter in the low pressure line would work well, but is bulky and adds restriction to the low side (kinda bad). A high-pressure T-style would be ideal, like these http://www.normanfilters.com/HighPressureMiniTee.html . I have no idea how expensive they are or if you can easily source them - I'm looking currently (half-assed) because I do want to do it. Link to comment Share on other sites More sharing options...
