justinquilliam Posted September 6, 2008 Share Posted September 6, 2008 is there any way to use a dana 18 or 20 in my 88 comanche. i have dana 60 axles and i want to be able to have front and rear wheel drive seperately. i know that the dana 300 is the best but the only thing i can find is 18 and 20's. Link to comment Share on other sites More sharing options...
Motion Offroad Posted September 6, 2008 Share Posted September 6, 2008 If your going to do an upgrade the D300 is really the only way to go if your doing a "junkyard" swap. It'll have to be flipped to fit in the XJ/MJ with a clocking ring but it'll fit. Still cheaper than an Atlas or Stak. Why not just run the Tera Low in the NP231? It can be bought for under $250 and is an easy mod to DIY. It'll give you what your after. With a heavy duty SYE with the larger output shaft and a chain upgrade out of a Chevy NP231 you'll probably still have less $$ than putting a D300 in and it'll be just as strong. Link to comment Share on other sites More sharing options...
justinquilliam Posted September 6, 2008 Author Share Posted September 6, 2008 i want to have front wheel drive only as an option Link to comment Share on other sites More sharing options...
justinquilliam Posted September 6, 2008 Author Share Posted September 6, 2008 i want to know about the d18 and the d20 Link to comment Share on other sites More sharing options...
reson46 Posted September 8, 2008 Share Posted September 8, 2008 i want to know about the d18 and the d20 Dana 18: Are you planning on installing front AND rear axles that are offset to the passenger side? If so, you will need to find out if it will even bolt up to your transmission. I know that there are at least three different versions of the D18. I believe the biggest difference between each is the different sized intermediate shafts. You would want to find one of the later ones with the larger shaft. Given all of this, would it be worth all the work? To me, no. But, you will have to answer that for yourself. Dana 20: This one would only require a front axle with a passenger side differential. You will still need to find out if it will work with your transmission. Willy Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted September 8, 2008 Share Posted September 8, 2008 I am not saying to buy this but these guys sure offer a lot of information on the Dana 20 for a Jeep. http://www.high-impact.net/transmission ... Bronco.htm i want to know about the d18 and the d20 Link to comment Share on other sites More sharing options...
justinquilliam Posted September 8, 2008 Author Share Posted September 8, 2008 i found dana 60's from a seventies ford, and i was going to do my own flip levers for the t-case. Link to comment Share on other sites More sharing options...
