What is "blow by"? More newbie questions.
Ok so has anyone used the 6 cyl rebulid in a can additive??? I put it in this oil change just to see if I notice anything good ..... :D
I don't know about "rebuild in a can" but if you want to really clean out the gunk inside your motor, I used "SeaFoam", can has all the directions, pour some in the tank, (while running) down the throat and into the vacuum system via brake booster hose, some in the oil (don't forget to change it afterwards). Mine smoked like a freight train for a little bit but now it runs a lot smoother and better. The only drawback I found is that the cleaning is SO good it caused the valve cover and oil pan to start leaking a bit (crud build up that was keeping old gaskets from leaking now gone)
