Pete M Posted September 12, 2008 Share Posted September 12, 2008 I tried one of those air breather on my truck and all it did was spew oil up into and then out of that breather. :( (admittedly my truck has incredibly bad blow-by) Link to comment Share on other sites More sharing options...
Redramman Posted September 12, 2008 Author Share Posted September 12, 2008 Might have to do hill billy jug anyway, but on this truck I can only fit a empty 32oz. gear lube bottle on the pasenger side next to the shock tower. Even though its a 4cyl the air box system takes up most of the driverside fender. How fast does your gallon jug fill up? Link to comment Share on other sites More sharing options...
ORCA Posted September 12, 2008 Share Posted September 12, 2008 Might have to do hill billy jug anyway, but on this truck I can only fit a empty 32oz. gear lube bottle on the pasenger side next to the shock tower. Even though its a 4cyl the air box system takes up most of the driverside fender. How fast does your gallon jug fill up? Mine didn't fill up very fast at all. Could be different depending on how bad the blow by is Link to comment Share on other sites More sharing options...
Pete M Posted September 12, 2008 Share Posted September 12, 2008 This one turned out to be ineffective. It filled up after a few hours on the highway on my way out to Moab. I dealt with it til Colorado and then fabbed what is there now. Link to comment Share on other sites More sharing options...
Redramman Posted September 13, 2008 Author Share Posted September 13, 2008 I might be able to cut a hole in bottle to fit the gromet and breather,and run the hose in jut past the breather opening. of course then emptying the jug might be harder. Maybe I could just hose clamp the breather to something and run 2 hoses out of bottle one to breather the other to valve cover.Or use a Y tube,the bottom of the Y to bottle etc.I just want to take the air filter box out of the ccv circuit. Link to comment Share on other sites More sharing options...
