comanche87 Posted August 20, 2008 Posted August 20, 2008 hi i am trying to find the electric fan connector. i put in a electric fan to help is any over heating happens. I'm looking to use most of the factory wiring. on non ac trucks where is the connector and where would the ac relay go. lookin to use that. could anyone help me out. thanks. :USAflag:
JohnQ Posted August 20, 2008 Posted August 20, 2008 My truck is factory non AC (right now anyhow) and I just ran my electric fan off from a switch and relay. Mine didn't have the plug for it on the wire harness.
deziped Posted August 20, 2008 Posted August 20, 2008 My 89 is non-factory air & the connectors are not present in it either. Just run a hot wire off the distribution block to a relay & go from there.
HOrnbrod Posted August 20, 2008 Posted August 20, 2008 Like John says, on non-factory A/C equipped rigs, the wiring isn't there and you will have to wire it in manually with a dash switch, relay, and a sensor (if you want it, recommended). Off topic JohnQ, but how is that cat doing??
JohnQ Posted August 20, 2008 Posted August 20, 2008 Off topic JohnQ, but how is that cat doing?? Cats are always better with no hair! :D
