control arm torque specs
Today I am installing my currie track bar and control arms. I read in chilton that the control arms only need to be tightened "finger tight", is this right? and if so, does that torque also apply to the currie setup?
Thanks
ok, I just found that on the web, it also says that the torque should be 55 for the uppers and 133 for the lowers, thanks maddzz1!
Also, when I raise the vehicle, should I support it by frame with the jackstands and take the load off the axle, or should I support it by the axle (still having load on the springs) with the jackstands.
I know, noob question... :dunce:
