BPB Posted July 30, 2008 Posted July 30, 2008 saturday a buddy and I are going to try to work out the electrical grmlins due to some tweaker's failed attempt at stealing my mj. seeings how rare comanchees are can i use the wireing harness out of a 1990 5spd 4x4 4.0 cherokee? every wire going to my steering column was cut, is there a plug "up stream" from there so that I can get just the wiring for the interior from a u-pull-it? tearing the dash apart isn't that bad, my heater fan is going out anyways.
Chico Posted July 30, 2008 Posted July 30, 2008 The wiring harness is one assembly from the fuse block to the connector for the rear lights/fuel pump. If you're using a cherokee one try and get one with the same transmission (auto or manual). You're going to have to splice wires at the connector that I mentioned because the actual connectors are differnt. One of the wires will have to actually run to the switch on the steering culumn. So it is very possible to use a XJ one, just a pain. I know, I did it. If at all possible try to get a MJ one.
