mvusse Posted July 15, 2008 Share Posted July 15, 2008 Definitely sounds like the clutch is not disengaging completely. It might need adjusted, if there is an adjustment, or there's air in the system. Link to comment Share on other sites More sharing options...
broythomas Posted July 16, 2008 Author Share Posted July 16, 2008 these aren't adjustable are they? Link to comment Share on other sites More sharing options...
BLHTAZ Posted July 16, 2008 Share Posted July 16, 2008 Sounds like either an air problem or low fluid. Both of those things will cause that problem. Could also be a defective new master...it happened to me on our YJ. Link to comment Share on other sites More sharing options...
Mountianrider Posted July 19, 2008 Share Posted July 19, 2008 Blhtaz is right, there is a leak in the connector and it is letting air in the system. Rebleed the clutch. Three or four good pumps on the clutch pedal should do the job. See how that works for a day or two, and if it repeats the same problem your going to have to use some teflon tape on the plumbing connectors. Link to comment Share on other sites More sharing options...
