jackel18 Posted July 9, 2008 Posted July 9, 2008 T&T Customs XJ Unibody Stiffeners does anybody know if they will fit an MJ at all? with/without a little modification?
CWLONGSHOT Posted July 9, 2008 Posted July 9, 2008 The MJ frame is different than the XJ in ways that it is already in effect "stiffened". Â I have no doubt a competent and astute person could make improvements. but for the vast majority its fine as it is. Â Make some improvements to the steering box area and call it good. Your efforts will be more fruitful in other areas. Â CW
Pete M Posted July 9, 2008 Posted July 9, 2008 Â The frame up by the steering box could definitely use a plate like the C-rok steering box brace (the spot between the steering box and trackbar mount is the problem area due to sheering forces and the two mounts fight in opposite directions as you turn.). The rest is waaaaay stronger than the XJ. :D
Pete M Posted July 10, 2008 Posted July 10, 2008 To anyone trying in vain to find the C-Rock brace, it's actually spelled "C-Rok". :roll: I've changed it in my first post.
