fender flares like these? i presume these are stock right? when i bought my comanche, there were no fender flares so i have to buy some.
Image Not Found
Those are stock flares. You can use 96 and older XJ front flares('95-'96 XJ flares taper out towards the front). You will need MJ flares in the rear since they have a larger wheel openings then XJ' do.
In the pictures below are front flares are 95 XJ flares that have been raised and reworked.
You can cut and raise them to the bodyline like this.
Image Not Found
Raised to bodyline.
Filled gap.
Modified inner fender liner.
Stuffed.
Flexing
Or you can get wilder like this.
Image Not Found
Image Not Found
Image Not Found
I just started cutting and reshaping the front part of the inner fender. The inner fender curve extends all the way to the core support.
I have raised my flares as much as possible, as I have posted before. It has 6.5" of lift with some wornout 31's on it right now. It will have 35" tires when it is finished.
Here is a picture of the inner fender after raising the flares with 33" tires.
Image Not Found
I cut the front of the inner fender for a dramatic increase in room.
My goal is to get as much uptravel as possible as part of my build.
I still need to do some more welding, then clean up and paint it.
Here is a picture looking straight down from under the hood.
Image Not Found
Here is a picture the inner fender. I gained 4" or more of clearance.
The difference is dramatic.
Image Not Found
There is now more room in front the tire then from the rear or above. I should be able to stuff the tire about 3" more and still be able to turn from lock to lock. As part of the build the front axle will be moved forward 1".
Comparison between stock inner fender and my cut inner fender.
Image Not Found
Image Not Found
I have since finshed the welding and cleaned up the weld lines.
:cheers:
