VA Jim
Everything posted by VA Jim
  1. I did this swap last year and it is a lot of work. You'll have to swap the wireing harness to get the hookup for the trans. computer. You'll also need the tps for the auto. Also I think most of the automatics had .355 dif gears. The front xj driveshaft will work, but not sure about the length on the 2wd mj rear shaft.
  2. I just did a swap to an automatic and the cable I used from a Cherokee went thru the firewall and over to the shifter. What the seller is telling you is correct. Jim
