CajunComanche
Everything posted by CajunComanche
  1. Been a while since I've been on here. Doing another restoration on same truck. I've done the interior and door swap.Put the 350 out of my 75 Corvette in it. Built a rack in back that holds spare and trans cooler. It will also hold jack,shovel,axe and a couple Jerry cans. Looks like I will have to figure out how to install pics again.
  2. Put a new Edelbrock 500cfm carb on the 4.3. The old Quadrajet was worn out.
  3. It's been a while. Bolted in Cherokee front 4wd axle.Have 700r4 4wd with NP207 transfer case bolted to it.Not the best transfer case but will work for now.Just purchased front driveshaft,axle shift fork,manual lock for front axle.Will have to cut down rear driveshaft and modify front. Probably gonna have to do a custom transfer case shifter. Hard to find one for the 700r4 and NP207.
  4. Kendall Guidry Conroe,Tx. 1987 Base 4.3 marine engine swap.
  5. Sold..I called to buy it yesterday 12/13.The guy sold it an hour before I called.
  6. Obviously death wobble is caused by several things since we have different situations.I know that heavy duty steering stabilizers has "fixed" my dw both on my Comanche and Ram 2500.
  7. Dropped my tank today to replace the o-ring.I didn't want to spend the 100 or so bucks for a new fuel gauge sending unit so I bought a $25 Autometer universal and bolted it to the stock arm.I now have a functioning gauge and I can fill it up without losing expensive gas.
  8. I have an 86 XJ with a 2.8 with every performance option possible including a Comp cam,Crane rocker arms,500cfm Edelbrock 4barrel,Edelbrock Torker intake,Headers,MSD 6A,MSD BLASTER COIL,and so on.In other words it's built to get as much power out of this lil engine possible.I have to admit it's peppy....but....I also have an 87 MJ that I swapped a 4.3 Chevy boat motor in it and it's like night and day when comparing power and speed between the two.My lil MJ is a beast and the 2.8 Cherokee is "ok". My 4.3 marine engine is rated at 224hp..I don't know the power output of the built 2.8 but it ain't no where near the 4.3..Keep in mind the Cherokee is heavier than the Comanche but trust me I much prefer the power of the MJ.
