mj88
    Colorado Springs, CO
mj88's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. thanks for the info. I went to the auto parts store and those are the right sensors. those knock sensors are not cheep.
  2. I'm replacing the engine in my 89 cherokee 4.0l and there are two sensors on the drivers side by the engine mount that i can't figure out what they are. one is just above the oil pan and behind the engine mount. The next one is directly under the engine mount. I went to the auto parts stores and they couldnt help. I looked on my other two jeeps for any part numbers but they didnt have anything. I'm trying not to go to the dealer my last time there was just :mad: . any ideas
  3. lucky were I'm at we don't have any emissions laws.
  4. will the auto trans from the 96 work in the 92 engine?
  5. I'm tryin to find a 4l engine for my brother in law cherokee, and was wondering if a 92 4l cherokee engine will work in a 96 cherokee. if not any one know what will work in the 96.
  6. i know its a late notice, but any one want to make a run up eagle rock this weekend? i was going to go with my brother in law but he now has new plans and can't make it.
  7. I replace the motor mounts about six months ago but i will check the trans........thank you
  8. its not a comanche but close. on my 89 cherokee the lever for the four wheel drive keep popping out of the braket. the bolt for the braket are a pain to get to without cutting the carpet. i put it back twice now. any ideas on a fix?
  9. cool thanks for the info i will post pics on the progress.
  10. I'm going to use cj 7 rotors there a little loose around the center but I'm not going to use the jeep on the road. (found out that would work through extreme 4x4). but if there are any other ideas I'm open for anything.
  11. I'm putting in a ford 9inch in the rear of my comanche and want to do disk brakes. I know what rotors to use but I don't know what calipers i need. Any Ideas?
  12. i have a 88 mj with the olypic package it is just a pioneer with gold stickers down the sides and on the back.
